Any progress on those samples?
Results 31 to 45 of 45
well, mytheatre seems to "fix" the dvb stream already. i can't capture with any other tools yet cause they aren't supported by my firedtv box.
you could test anyway,
https://www.videohelp.com/temp/050616_172021%20SVT2%20Vasterbottensnytt%20De%20sista%20...kandonerna.mpg -
download hdtv ts samples from
http://www.dododge.net/roku/ts-samples.html -
Thanks for the links, not looked at DVB streams before, I see them '.ts' files have multiple channels/streams/pictures inside them.
Obviously they wont work, as they are, with avi.NET, but when you extract the mpg out of them, like I presume you did with your 'mpg' clip, it will work fine. -
ok. wanted to give it a try but the d/l link keeps bringing me back here. where can I d/l it ?
@ Baldrick I click your link. it takes me to the other thread. I click the link to the tools section. In the tools section when I click the d/l url it keeps taking me back to the other thread.
Click on the avi.net v0.5.2 link in the first post in this topic....it is just above the latest version history....yes it is confusing...but it is a beta...
or click on the link here
https://www.videohelp.com/forum/viewtopic.php?p=1332350#1332350"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
so if i understood this thread correctly this is an encoder for avis to xvid/divx [xvid only:without gmc / qpel correct]
will this be similar to autogk? -
avi.NET also now (RELEASE CANDIDATE 1) includes something of a 'Backward QF' calculation. This is to make things a little easier for the user. Upon loading a movie or film clip e.t.c it will use a baseline QF of approximately 0.20 and calculate a size/bitrate for you automatically. This actually choses a '.Custom Size' and calculates a given size/bitrate. Again, this is just a starting point for you, you can then change/select your required size/bitrate.
After checking all the code and no doubt checking it all again, I see no reason why avi.NET should not go out of beta/release candidate status.
Unless you disagree or some kind of problem still exists avi.NET will go to proper release status.
Thank You to everyone who tried it. -
Just ran two movies through it successfully with an old PIII-600 and had no problem. Processing time was about 8 hours each which is comparable to AutoGK using MP3 output. There is alot to be said for the simple interface. The one AutoGK feature I would add is the automatic cutting of the movie into CD-R-sized sections. It is definitely a tool I will keep my eye on.
any encoding problems with windows 7 release candidate?
By uglijimus in forum Video ConversionReplies: 5Last Post: 1st Sep 2009, 12:38 -
AVI.net a confusing problem : using DivX instead of XVID
By Alterego in forum DVD RippingReplies: 5Last Post: 17th Jun 2009, 12:39 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 08:32 -
ConvertXtoDVD 3 Release Candidate available
By clairew in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2008, 23:02 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
